Hi everyone,
I need help solving a problem in Grasshopper. I need to transform the list on the left into the list on the right, following a specific sequence rule. Here’s the rule:
Start with the first item in the list (5).
Use its value to determine the next index to visit (5th item).
From there, retrieve the value (6) and use it to determine the next index (6th item is 8).
Continue this process until all items are visited.
Can anyone help me find a solution in Grasshopper?
If you don’t mind using ghPython, this is what you asked for:
def main(input):
result = []
index = 0
for _ in range(len(input)):
result.append(input[index])
index = input[index]
return result
result = main(input)
Essentially you want to loop through the results and use the value of the previous output as the index of the new one. The easiest one I can think of (yet not very scalable) is using list item > index of the new list item. See image below. However as you might want to expand the list it’s best to look for a loop solution.
Thank you all for your help! I’ve successfully solved the problem. The code ended up looking simpler than I thought, and all the solutions shared were great.
I really appreciate the time and effort you took to assist me.
