I am trying to create a surface from three curves. I would like the surface to follow the edges of all the curves, however they are creating folds and I am not sure how to prevent this.
I was thinking that the Two rail sweep was the best to use but I am not sure, any help on this would be appreciated. Attached are some images and the grasshopper file.
Thanks guys, yes I realised that my ends were not closed and so I closed them up and tried the surface patch. It gives me more or less what I want.
The panelling is behaving quite strange though, il do some research and see what I can do. I am using the lunchbox plugin and trying to divide the surface with the the Quad panels.
LB works on a Surface basis … so it gets the Underlying Surface from a given BrepFace and does what it does.That said a BrepFace is a Surface with trims.
Other than that for “similar” things I would strongly suggest the reverse way: do some blob (using stuff the likes of TSplines - dead but alive), define Curves with some way, join them and then (if they yield a single Curve) attempt to split blob’s BrepFaces. That’s a bt tricky without code … but is doable anyway.
