i dont know what im doing wrong, i cant achieve to record the movement of fluids on the topography,
hope you can help! Thank you
Switch the run toggle to true.
Couple things Iām noticing:
I was able to get the script to work this way, with one little glitch that hopefully someone else can solve: The points are following the topology of the mesh, but below the mesh at the distance set by the load.
It looks like you are using the definition from here:
but as pointed out, it looks like the Load goal has somehow been accidentally connected to the wrong input. Once this is changed it should just be a matter of setting the toggle to true. When you want to clear the traced particles, you can click the X of the Record component.
