FlowAlongSrf working bad
I’m trying to make a FlowAlongSrf an i think the result is wrong, i made a flow from the green surface to the red surface, and the objects that are all inside the base surface is good, but the objects that are a litle oustside the surface is wrong( the objects are all the sime size). Can someone help me.
Pedro Neves
FlowAlongSrf_BAD.3dm (2.1 MB)
Hi Pedro -
It looks like this command is not designed to be used this way.
Perhaps this can be tuned up at some point
→ RH-97925 UDT: FlowAlongSrf: Object Outside Base Srf
For the time being, make sure that your base surface is large enough.
Hey @PedroNeves,
Manually in Rhino you could get away with CageEdit: by using the source surface as the cage and scaling it:
Alternatively, for something like this, Rectangle Mapping in Grasshopper should do it:
RecMap.gh (35.8 KB)
Check:
FlowAlongSrf_Not-too-BAD.3dm (256.6 KB)
