i have issues with FlowAlongSrf. it creates jagged outer boarders. the tolerance has no influence on the results.
check the file. the error can be reproduced.
thx in advance…
FlowAlongSrf.3dm (681.5 KB)i have issues with FlowAlongSrf. it creates jagged outer boarders. the tolerance has no influence on the results.
thx in advance…
FlowAlongSrf.3dm (681.5 KB)Hello - try making your base and target surfaces slightly over-sized:
thx pascal, but isn t it a bit inaccurate workaround when you change the source srf? did you scale or extendsrf?
Hello - I used ExtendSrf. If you’re careful about extending, I don’t see why this should be any less accurate. You will have to choose a location on the curved surface to measure the extension - I suggest making the corners match the base surface offset.
