Is there anyway to flowalongsrf so that geometry wraps over the seam? With A, the geometry continues in the tangent direction, which is not what I want. And with B, there are seams in the geometry that could cause problems down the line. I can see how there would be problems if the there was anything less then G2 continuity at the seam. In my case, I am only working with tubes.
Hello - you can trick Rhino by making a wrapped circle and extruding that.
- Make an arc.
Extend, Type=Arc and extend it to wrap around on itself. - Gumball - extrude that curve.
UnrollSrforUnrollSrfUVto make the base surface. -
FlowAlongSrfback to the wrapped cylinder.
Flow-n-wrap.3dm (333.0 KB)
When I go to extrudecrv, I get a popup about self-intersecting curves. The resulting geometry is a segmented cylinder (multiple unjoined surfaces).
Ahh… try Gumball (extrude) , I think that is what I used, actually.
Great, thanks. That worked.
