Did this function only work until Rhino 5? :sollozo:
flow-notwork-in-a-group.3dm (54.7 KB)
I’ve also noticed that ctrl c and ctrl v is very slow
while if Copy InPlace is used; It works immediately, that’s very rare.
Hello - I’ not sure I understand the question(s) can you tell me what version of Rhino you are asking about and what goes wrong?
I am trying to flow some curves around a circle with the rigid option. then I group them to add adjustments at the end using the record history, as you see in the example the curves are not wrapped in the circle; really it is rigid
but both version 6 and 7 are not working
Hello - in V7, use the RigidGroups=No Option, does that get what you need?
I am very grateful to you
Ok, that works for me.
just asking; in v-6 how would it be resolved?
Hello - there is no good way out in V6 - in V5 there were a number of requests for V6 style rigid groups, then, naturally, in retrospect, requests for non-rigid ones as a consequence, so the option was added in V7.
