I watched a Youtube viddy about how to create a tire and have tried to duplicate the procedure on the Mac, but am getting stuck at the Flow Along Surface portion.
I am attempting to wrap a solid extrusion (or even its source curve) along a revolved surface (think tread and tire).
I initiate the command, I select the base object, {enter} but when I try to perform the next task, Select Near Corner, I click where I think I should, but the command never advances to the next step, Select Target Surface.
Same response whether selecting the extrusion or its source curve.
I can get the base object to wrap the entire surface if “Plane = yes” after prescribing the requisite rectangle, however it covers the entire surface instead of only the part I wish to cover.
I’m clearly doing something wrong. Is it a layer thing, a geometry thing?
Bug? (please let it be a bug so I don’t look like a total retard).
