See attached please. I’m trying to create a closed object that conforms to a spherical surface.
http://www.screencast.com/t/RNIlTXKw
Chef’sPan_Metric copy.3dm (727.6 KB)
Are you trying to make cutter for the handle for the scoop part ?
Chef’sPan_Metric copy-RG.3dm (792.8 KB)
I’m trying to make a cutter for the handle. I used the bend tool, but I don’t think there’s an option to bend both ends in the mac version so I had to bend and then rotate. As you can see from the screenshot, it doesn’t make for a very accurate cutting tool.
Yes, that looks like what I’m after!
It’s in the file I uploaded earlier … sweep 2 rails using your handle cutout curve. The one that was highlighted in your first screenshot.
Revolve
that shape curve on the center of the pot?
Oh, well yes… that’s a bit embarrassing.
Thanks for the help rudi
