Flow along Surface or Squish Back
Hi ,
I’m Trying to put a design on puffy surface but I’m not able to achieve that as flow along surface is tight the design on the end because it’s not rectangle design .
Is there away to put the design on the puffy surface without change it "just make it curve on the surface "
File
Hello - you’ll need to make a temporary target surface that is more rectangular - can you post a file with that tear-drop shape?
As the file is big, I have put it in my share drive, you can check it .
Hello - just please export the target surface, no need for the entire project.
That is what I did , but there are a lot of curves which make it big .
Hello - select the surface - just the surface and `Export Selected’ from the File menu.
Still, it’s big
