Flow Along A Surface Questing
I’m trying to flow a surface around a polysurface, but I’m not getting the expected result. I’m not sure what I am doing wrong. These are the steps I’m following:
This is the object that I want to wrap around the target object.
I created a polysurface that I want the surface to flow along (Target polysurface).
I used the CreateUVCrv command on polysurface above that I’m using as the base object and added a reference point.
When I run FlowAlongSrf, this is the result I get. I was expecting the surface to wrap around the target object (but keep it’s dimensions), but I’m not getting the correct outcome. What am I doing wrong?
Ideally, I want the flowing surface to conform to and wrap around the target polysurface but keep it’s dimensions.
Thanks,
Veronica
The FlowAlongSrf command morphs objects from a source surface to a target surface (not polysurfaces).
You can split the object to be flowed into a part for each surface, and then flow each part separately.
Hi @veronica.hubbard
If the target shape is a simple rounded shape like shown, using Bend would be an easier alternative - see vid.
HTH, Jakob
Hi Jakob,
Perfect! This is exactly what I needed it to do. I tried using the bend feature, but I think my settings were different, so I believe that was my issue. Thank you so much for your help and for the video. I really appreciate it!
Thanks Again,
Veronica H
Thank You David!
