Floating Command Window
Is there a way to make the Rhino command prompt into a floating window?
I know I can push F2 to get command history, but I’m wondering if I can have the active command prompt in a floating window the same way.
Like other toolbars you can simply drag the command prompt outside to make it float.
CommandLine
The Macro Editor panel can also be used to run commands and much more.
Thank you! I didn’t even think to try to drag it like that. I don’t normally do that with my toolbars either, I right click on the main toolbar and go to Show Toolbar and pick the one I want.
