Flip Surface Normal towards a point
Hello All, I have a bunch of vertical surfaces and a point in between all of them. As you see some of the surface normals are pointing outwards and some in the direction of the point.
I’m wondering if there is a way to flip all the surfaces so that all the surface normals point towards the point, as I manually did here:
here’s the file:
flipsurfacenormaltowardsapoint.gh (21.4 KB)
Thank you!
Renan
flip.gh (9.6 KB)
Or like this
flipsurfacenormaltowardsapoint_dfytz.gh (12.4 KB)
You could also use Plane Closest Point.
flipsurfacenormaltowardsapoint_re.gh (11.0 KB)
wow, never thought about it this way!
I think in his example the surface happened to cover the “center point”. but not his original intention.
Thank you all so much this works!!
Improved a little bit the HS_Kim definition and eliminated the need to define a point.
Flip_Surface_Normal_Towards_Point_re.gh (11.2 KB)
Nice! even better, thank you
R
