Hello everyone!
I am working with this set of volumes, and I would like to organize them in two different ways: by floor (like in the screenshot with colors) and by column of boxes (vertically).
I am not really sure of how to do it since I’m pretty new working with data trees, however I believe that path mapper might be able to help me, but even with watching David Rutten’s couldn’t do it…any ideas? Thank you!!
hi flow23
say your paths are {A;B} then to flip that you will use flip matrix or path mapper to make: {B;A}
in the case you had multiple branches then you use the path mapper to rearrange them like say:
[A;B;C] flipped to [C;B;A]
so just plugin your path mapper and choose ‘null mapping’
then double click on the component and change the mapping as you like
*it may also be usefull to simplify / trim your branches to remove empty overlaps first
here is a good video about path mapping:
it is pretty simple
yrs, arkadius
Thank you all so much!!! It helped me a lot!
