i wonder if there is a fast and easy way to swith between snappy and smooth gumball?
i would just love to use SHIFT (or other programable key) for gumball to snap in smooth mode, or be loose in Snappy mode.
best,
Vladimir
best,
Vladimir
Hi Vladimir -
You can assign the following macro to a function key or alias:
-Options ModelingAids Gumball SnappyGumball Enterend
A slightly more complicated way to do it is with a script. The only advantage to this is that you can get feedback on the command line about the current state. I use the attached script, but it’s not nearly as good as having an override key.
You’d need a macro like this assigned to function key or alias:
-runpythonscript “full path to script including name.py”
ToggleGumballSnap.py (487 Bytes)
Hey Peter any idea on how some people have been able to edges by snapping whilst using the gumball on subd objects?
Sorry - I don’t understand what you mean.
