HI,
we have a custom render mesh provider in our plug-in but it seem to behave weirdly when the option flat shade is activated. The image below shows a side-by-side of the same mesh visualized through the custom render mesh provider and when the render mesh is extracted. Works correctly in Rhino 7
The issue does not appear on normal (i.e. not flat) shading. Is there some flags to use/set or something we are missing? The code that does the visualization is:
public override RenderMeshes RenderMeshes(MeshType mt, ViewportInfo vp, RhinoDoc doc, Guid objectId, List<InstanceObject> ancestry, ref Flags flags, RenderMeshes previousPrimitives, PlugIn plugin, DisplayPipelineAttributes attrs)
var rhinoObject = doc.Objects.FindId(objectId);
if (rhinoObject == null) {
return null;
return ComputeMeshes(rhinoObject);
private ComputeMeshes(RhinoObject rhObj)
if (m_runtimeCache.TryGetValue(rhObj.Id, out uint runtimeid)) {
if (runtimeid == rhObj.RuntimeSerialNumber && m_generatedMeshes.TryGetValue(rhObj.Id, out var cachedMeshes)) {
return cachedMeshes;
var meshes = BuildRenderMeshesFromObject(rhObj);
var renderMeshes = new RenderMeshes(rhObj.Document, rhObj.Id, ThisId, m_internalHash);
m_internalHash += 1;
var material = rhObj.GetRenderMaterial(true);
for (int i = 0; i < meshes.Length; ++i) {
renderMeshes.AddInstance(new Instance {
IsViewDependent = false,
Material = material,
Mesh = meshes[i],
IsRequestingPlugInDependent = true,
Transform = Transform.Identity
m_generatedMeshes[rhObj.Id] = renderMeshes;
m_runtimeCache[rhObj.Id] = rhObj.RuntimeSerialNumber;
return renderMeshes;
