see attached file.
Q:
How can I fix the lower point of the orange part (where the annotation dot is?
Thanks,
-C-H-A-R-L-E-S-
CP_Fix.3dm (66.0 KB)
see attached file.
Q:
Thanks,
-C-H-A-R-L-E-S-
Like this?
CP_Fix 001.3dm (216.7 KB)
If so, what you need to do is to change the pivot of Objekt 26 and make it into a joint so that it can move.
Move also the pivot of Objekt 38 to the corner where the movement is starting from and make it into a joint.
Add a point to where you want Objekt 38 and Objekt 19 to stay connected. Constrain the point to Objekt 25, which is achild of Objekt 19.
Hi Marika,
yes, that’s it exactly.
Thank you for the detailed explanation, that helps.
-C-H-A-R-L-E-S-
