When using SubD commands such as Stitch or Bridge, after selecting the first element and pressing Enter to proceed to the second selection, the first selected element is no longer visually highlighted. This issue occurs regardless of the selection type (vertices, edges, or faces), making it impossible to identify which element was initially selected while making the second selection.
Hi Sopdet -
Please run the Rhino SystemInfo command and copy-paste its output here.
Rhino 9 SR0 2026-10-27 (Rhino 9, 9.0.26300.09401, Git hash:master @ b5c4aa079c11dd91ccd7b6aa067f5029f3fccf72)
License type: Commercial, build 2026-10-27
License details: Cloud Zoo
Windows 11 (10.0.26300 SR0.0) or greater (Physical RAM: 64GB)
.NET 10.0.2
Computer platform: DESKTOP
Standard graphics configuration using OpenGL
Primary display: NVIDIA GeForce RTX 5070 Ti (NVidia) Memory: 16GB, Driver date: 7-22-2026 (M-D-Y). OpenGL(4.6.0 NVIDIA 610.88)
Accelerated graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-22-2026
Driver Version: 32.0.16.1088
Z-Buffer depth: 24 bits
Total Video Memory: 16303 MB
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Cooperlake MAX_THREADS=64.
C:\Program Files\Rhino 9\Plug-ins\Commands.rhp “Commands” 9.0.26300.9401
C:\Program Files\Rhino 9\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 9\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 9\Plug-ins\RhinoAI\net8.0\RhinoAI.rhp “RhinoAI” 9.0.26300.9401
C:\Program Files\Rhino 9\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
C:\Program Files\Rhino 9\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 9\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26300.9401
C:\Program Files\Rhino 9\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26300.9401
C:\Program Files\Rhino 9\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26300.9401
C:\Program Files\Rhino 9\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26300.9401
C:\Program Files\Rhino 9\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26300.9401
C:\Program Files\Rhino 9\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9\Plug-ins\SectionTools.rhp “SectionTools”
This bug is seriously disrupting the modeling workflow and causing significant frustration. Is there any chance it will be fixed soon?
Hi Sopdet -
This is not something that I can reproduce on my machines here.
Are you using customized display modes?
I initially thought the issue might be caused by changed settings, so I went through each tab in the Options window and restored the settings to their default values. However, the bug still occurs exactly as before.
Additionally, I tried performing a factory reset by running the Reset command, but this did not resolve the issue either.
This is a video reenacting the situation.
Did you watch the video?
A pop-up appeared for a new update (Rhino 9 SR2 2026-11-10, Rhino 9, 9.2.26314.10001); after completing the update, the issue disappeared. ![]()
