Firefly Serial Read is empty
I connect an Arduino Pro Micro to Firefly in Rhino 7. Everything is working in Arduino IDE, I get a list of values like 1,2,3,4,5 but in Firefly it is empty. Baud rate is matching the code, port is correct
Might want to hold off, i believe @AndyPayne is in the middle of a re-write.
Depending on what you intend to use Firefly for, this thread may be helpful to you.
Thanks, SuperSerial solved the problem
