Hi There,
I have a grasshopper script that simulates a folding pattern using Kangaroo solver and hinges command.
The Kangaroo command works all good but I am having difficulty finding the right points as folding points.
currently, the folding points that I am giving to Hinge component are not right, therefore, the folded simulation is as follows:
But the final state that I am trying to fold it into is as follows:
I can choose the points manually, but I want to have the code parametric therefore I rather to find the points through the script.
Can anyone help me, please?
here is the grasshopper code:
FoldingSimulatiion.gh (23.3 KB)
Thanks in advance.
Draw which points do you wish to select.
If the whole sheet is made of 8 pieces of pink highlighted 4 sided polygons, I want a list of points that are tagged as 0 of all the 4 sided polygons, a list of points tagged with number 1 and a list of points of tagged number 2 and a list of points tagged with the number 3.
so it will be as following:
List one:
{Point 0, polygone 1,
point 0 polygone 2,
point 0 polygone 3,
point 0 polygone 4,
point 0 polygone 5,
point 0 polygone 6,
point 0 polygone 7,
point 0 polygone 8}
and the same for points 1, 2 and 3.
here is the reference image:
Here…
FoldingSimulatiion.gh (27.2 KB)
There is a bit more work to be done, but I am sure you can do it…
