Your image is upscaled. Each pixel was transformed in 5x5 pixels (or more) and blurred with neighbors, losing accuracy of colors and such.
Do you have the original image? (always in .png )
after getting a very clear image as Riccardo suggested, you can Brute Force this thing using standard components, like getting the color of a given pixel by using the Image Sampler component, or equivalent components from other plugins such as Firefly
after getting the -huge- list of colors (one RGB value for each pixel) with the Member Index component you can search for the occourence of each color you are interested in
consider that in my example I have just plugged in your original image, so it’s kind of blurred, and I am analyzing the original image comprehensive of the color-legend on the top left (you want to create a copy of the image to be analyzed, that does not contain the legend, otherwise also those pixel colors will be counted)
yes, you are right, brute force is not the right term here
I just wanted to underline that, for the solution I proposed, the calculation time is directly related to the number of pixel, in a kind of “process them all” way, no shortcuts of any kind
