I have this set of drawings. I am trying to locate where these different tangents intersect at 90 degrees (within the precision of 1 degree or so) . Is there a command that will locate and indicate these types of intersections?
There is no single command that will do this. That said, it may be possible to write a script that will accomplish this.
Why do you need to do this?
What are you looking to accomplish?
If the was a command as you describe, would be the the result of the command?
Thanks Dale,
I was trying to exploit the drawing for design opportunities. I don’t really need the command. I thought it would be interesting to see if there was something really simple inside of the confusion of all those tangents.
Thanks again for the reply!
