Finding Curve Corners
Hi all
i have a set of curve , how to set seam at sharp/kinky corner ?
here for example red mark to be set as new seams
how to sort kinky point based on intensity?
thanks
SeamAdjust_001.gh (14.0 KB)
Sorting the t parameters of the discontinuities according the angles of incoming vs. outgoing segment, you get this:
It’s matches your sketch except on the outer two curves.
The outer three curves have a different looking corner with an additional segment. It might be better to adjust the seam just for one of your curves and only then offset the curve.
SeamAdjust_001.gh (28.2 KB)
Sir, Thank you so much. Fast and Clear.
