Rhinos,
In Rhino 8, if I bore a hole in a solid by subtracting a cylinder using Boolean difference, then try to find the center of the created opening in a surface of the solid – nothing happens. If I create a circle from the edge of the opening, then try to find the center of that – nothing happens.
Attached is a drawing with the circle from that process.
My workaround is the create an even number of points on the circle, then draw a line between two opposite points, then place a point in the middle of the line. Not very speedy.
I realize I’m misunderstanding something or making some simple mistake but what?
Not feeling brilliant,
Hilary Smith
Pacific NW USA
Circle With No Center 2024-03-13.3dm (72.1 KB)
