I fail to understand why the top group result is different from the one where I cast the text into points. The latter is quite a bit slower, so I’d prefer to continue without the casting text to points. Any pointers?
Instead of relying on point to text conversion, you can cull duplicates and find closest points. This way you get the point index of each point.
I don’t think what you do here is correct:
You should use the member index component instead:
Anyway, here’s the file with my approach not relying on text conversion:
unique point pairs mrtn.gh (36.3 KB)
