Find Surface UV #
Hi all,
Lately I’m wonder, is there a way to find a linked surface’s UV # in GH?
Something like type “What” in rhino.
If there’s a way to get these numbers from original surface it would be handy for my later on perimetric set up.
If you plug a surface into a UV^2 parameter, you’ll get the uv domain.
Thanks David, and is there a way to find the UV count?
There is no count. Count implies a distinct number of something, uv-domains are just two numeric intervals. An interval is a portion of the number line, starting at one value and ending at another, and containing all the numbers in between.
Ok got you David. I found Surface Points can do the job I need!
