I have two question about similar curves
1:
I have many curves.
and need using C++ codes to divide them into groups along the curves‘s Similarity。
how can I do?
2:I have two group curves named gruop A and B (these curves are not sorted )
which can be merged to two closed curves.
one closed curve is inner the other.
one curve in gruop A has a similartity curve in gruop B.
How can I find the corresponding curve in gruop B?
similarCurves.rar(6.0 KB) is a just simpely test sample curves.
in this example: I need find the same color curve along the outside curves.
2:RhinoMergeCurves can make them to two closed curves
but before that I need find the same color curve along the outside curves.
you can see my test sample curves,maybe be can unstand what I want to do.
1.) So by similar shapes, you mean “find all lines” or “find all circles”? If this is the case then you might take a look at this code sample and see if it gives you any ideas:
dale:
Thanks for you help
maybe I explained my problem not clearly.
These ideas are not I needed.
I am sorry for my poor english.
I will think how to sovle these problems myself.
If I still have’t ideas,I will try explain my problem more clearly.
Thanks again.
I am reviving a thread from last year to ask “why does it seem so difficult to come up with a script that can find duplicate objects that do not overlap?” Any kind of duplicate objects, from a simple two point line to a closed four sided curve loop, to more complicated stuff. I posted a request in the Scripting forum and the only answer I got was from Mitch who has a script for finding closed objects that have the same volume.
I use a very large spatial hashtable to find overlapping ( or similar) curves:
The nice thing about this aproach is that it keeps the runtime linear.
from collections import defaultdict as defD
crvs = rs.GetObjects(filter=rs.filter.curve)
tolerance = 1.5
# hash function considering tolerance
def tup (pt):
x=int(pt.X/tolerance)
y=int(pt.Y/tolerance)
z=int(pt.Z/tolerance)
return x,y,z
D={}
X=defD(int)
for crv in crvs:
pts=rs.DivideCurveLength(crv,tolerance*0.7) # space points a bit thighter tan tolerance
tp=0,0,0
for p in pts:
t=tup(p)
if t<>tp:
if t in D:
ocrv=D[t]
c2 = ocrv,crv
X[c2] +=1
else:
D[t]=crv
tp=t
for (t,o),k in X.items():
if k > 5: # require an overlap at 5 locations within tolerance ?
lo=rs.CurveLength(o)
lt=rs.CurveLength(t)
if lo < lt: # select the shorter of the two curves
rs.SelectObject(o)
else:
rs.SelectObject(t)
