I’m working at a lighting design office and perform day lighting studies in Rhino with Climate Studio.
We receive 3D models from architects and have to first clean them up. The most tedious part is, that glass surfaces e.g. windows should consist only of a single surface. In the architects models windows, however, commonly the glass panes consist of two or more surfaces, which are only a few millimeters apart. This means we need to manually delete all of these “almost duplicate” surfaces. By almost I mean, that they have the exact same size, at least one coordinate would be identical (depending on the orientation and rotation) and the other two would almost be the same. Maybe this could be solved with a tolerance slider. It doesn’t really matter which of the two “almost duplicate” it selects.
Does anyone know a script that could solve this?
