BTW, I’ve found that docking Filters to the left of the command line it pretty efficient in terms of screen real-estate, since the command area is generally wider than is really useful.
HI Charles - I changed the bug item so that you can see it now, I hope. As for docking… if toolbar locking is not on, it should just work - float Filters and OSnaps, and then drag them up against the left or right edges of the Rhino window at one end or the other of the command area - drop when you see the blue preview rectangle show up in the right place.
yes, I have it docked.
I had to undock it first, then redock.
I tried to move it from docked state to docked state, which is expected to work, but doesn’t.
Ok, not a big deal.
The docked filters are pretty useless this way.
An idea is to have the filters as a menu in the Osnap box.
Then they are where they belong to, and they are always visible and accessible.
