Filter object types in viewport?
Are there plans for a feature to be able to set display options on a per-viewport basis, so that you can filter out certain object types in a given viewport? For example, set the perspective view so that Dimensions and Curves do NOT display there? thanks! -d
This is controlled by the display mode used for any particular viewport. In Preferences (Rhinoceros drop down menu) you can make a copy of any display mode so you don’t affect all viewports using that mode. Assign that copy of the display mode to a specific viewport. Then, using the display inspector on the right (flat screen monitor icon), uncheck curves and annotations.
Wow thanks Brian - didn’t know about that feature. That’s fantastic!
A post was split to a new topic: Filter object visibility by parameters?
