Filter directshape generic models
I imported a site and context model from Forma. The context buildings are imported as Directshape Generic models.
Some of these have been deleted and re-modeled as in-place generic models.
I need to select all of the remaining Directshape generic models. My objective is to move them to the ground plane of the model. I am trying to select only the elements that are buildings so I’m not sure if this selection needs to be further filtered or if the desired filters already accomplish this.
I would assume that moving these elements involves deleting them and recreating them at the correct location. I would appreciate any input on this strategy. However, I haven’t been able to set up the correct filter definition. This is the main issue I am trying to solve. I was not able to put the pieces together based on what I found online, but it seems to be not that complicated.
Some of the elements have phase parameters but it isn’t such a big deal to preserve these, I can manually reset the elements to be demolished upon recreating them.
Thanks for any help with this!
model group internalized.gh (8.0 KB)
Hi CT,
I recategorized your post to Rhino.Inside.Revit
Its not clear what you are asking for. Can you provide a small sample file and details ? Thanks
Here is a one liner that returns True or False if the Element is a DirectShape
R8-RiR-DirectShapeTest.gh (7.2 KB)
you could also do a class filter
Thank you, I combined this second method with this to target the desired elements:
