Filter and create tri/quad meshes from polygons with more than 4 sides
my tutor has fixed up my grasshopper and i think i understand all the edits he has made (everything in the white groups) but he has set me this task and im not really sure where to start or how to go about this.
any help is really appreciated!
Floret dome_JD.gh (49.0 KB)
:rofl:
P.S. That was R7, this is R8:
oh yea sorry i should have mentioned it needs shapermap and pufferfish as additional plugins
this is my best guess, for each petal to create a quadmesh + a trimesh:
Hello
you don’t need plugins for this.
Bounding rectangle is replaced by
For the projection on sphere, uses Mobius transfomation
You have 2 inputs, the circle
  • List item
you can choose to put the center on a polygon pike
the radius
Then play with T to deform or not the shapes
And for the mesh, it is easy, just uses the curves control points
You can then measure the bounding box to get the sphere radius. There is surely a simple equation to do that!
Radius = Circle Radius / Sin(T)
Center = Circle center + Circle Normal * Circle Radius / Tan(T)
To get the sphere you can use “Sphere Fit”
Floret dome_JD_LD.gh (21.8 KB)
Thank you so much for your reply, I will have a look when I get back from uni alittle later!
WOW :exclamation: Bravo! All very good and Möbius Transformation is magic. :+1:
this is super helpful thank you so much, i wanted to try to put your mesh construction bit into my script so i could have both working, i had to figure out the points on mine and found its this (it took me longer than i would like to admit to figure this out lol)
but this happens? i dont even know where to start fixing this, do you have any ideas?
i havnt done much past adding your construct mesh bit at the end but i will add the file again just incase
Floret dome_JD.gh (51.5 KB)
I used “nice” ordered polygon for a reason.
If you want to use randomly ones, you’ll have to do a bit more work.
You can reorder them with the angles, or the side lengths …
Up to you.
okay thank you so much, thats super helpful again, i will play around and see if i can figure it out!
