Filling in Complex Slots
I have a model that is quite complicated that I imported as a STEP into Rhino. Very curvy surfaces. I have several “slots” that I need to cover up and not sure of a good method. I tried duping the edges and that seems like a start. Thanks for any advice.
You’re gonna want to just Extract the surfaces around the notches, delete the notches, then Untrim the surfaces…then re-Trim them back up. Of course the fact it’s imported geometry means this job might be more annoying than if it was native Rhino…
Also give a try to _ReplaceEdge command is not mainstream but in this situation is a life saver
