FilletSrf questions again
I continue to struggle with FilletSrf; what am I doing wrong??
Art
another FilletSrf challenge 2.3dm (775.8 KB)
Looks like it needs manual work, Maybe some pipe trim trick and curve blends
after some clean up (which is maybe not needed) explode the geometry, trim the little snippets off join it back together.
challenger.3dm (308.4 KB)
geemix-
Thanks; exactly what I was looking for/attempting!! can you describe your method/process in “baby steps”? your student is sloooooow :grinning_face:. “explode” what? the posted file had been exploded prior to the attempted “FilletSrf” operation. “trim” what?
Art
You have a V8 file to look at?
sure!!
another FilletSrf challenge 2 Rhino 8.3dm (824.8 KB)
FilletSrf and Trim work all right. On the inner, you can just about fit a 0.013 radius “G2” fillet because of the extremely acute angle on the bottom.
another FilletSrf challenge 2 Rhino 8.3dm (2.5 MB)
Lagom-
Outstanding; Thanks!! how do I get from what “FilletSrf” is currently giving me to your two solutions using Rhino 8 ??? think baby steps since I’m not seeing even the outline of the path…
Art
All I did was to explode the surfaces in your file, then split the funnel surfaces in half, then used 0.026" and 0.013" to FilletSrf with the G2 option.
is VariableFilletSrf the correct/best tool to use for creation of a variable radius fillet from the bell mouth to its base?
Art
inboard updated base Rhino 8.3dm (620.8 KB)
If you need a variable fillet, you’d use the VariableFilletSrf tool.
VariableFilletSrf.3dm (2.1 MB)
AI slop answers.
VariableFilletSrf (Rhino 8) is currently not producing a valid intersection on either surface in play. are there one or more common problems or is it simply a trial and error use case?
inboard updated base Rhino 8.3dm (665 KB)
Works here, Rhino 8 macOS, with R 0.01 to 0.1 and the classic SetPt pointy fillet snap at the dodgy end.
inboard updated base Rhino 8.3dm (2.8 MB)
Took me a while to get it :joy:
Good eye :face_with_monocle:
