Filleting of polysurfaces with multiple edges
the attached file shows a typical recess fon an instrument, i wanted toi fillet all the edges,
fillet and blend does work ok, bu t the intesection of the three edges fails.
tacktickinstrument.3dm (239.8 KB)
Yep, that is a nasty corner- It’s hard to even tell easily what the right answer is - I’ve attached what may be it - made entirely from FilletSrf, trimmed in ‘by hand’. It would be a little simpler of the edges that are almost tangent were truly tangent.
tacktickinstrument_PG.3dm (443.7 KB)
BTW, I would model this starting with the file’s tolerances at .001, not .01 - I did not notice that until late in the game so I left it. Some info here - http://wiki.mcneel.com/rhino/faqtolerances
Other Cad modelers with more robust fillet commands can handle this. However the fillets are very complex resulting in B class surfaces. It’s always better to create topology that allows for fillets to flow smoothly to achieve A class results.
Yeah- this is a cleaner solution than the first one, starting from the existing file- not too bad actually.
tacktickinstrument_pg.3dm (360.6 KB)
This is another way of doing dash gauges. I did this a long time ago so I’m fuzzy on the steps.
very nice indeed, thank you, is there a thread that explains the workflow?
Es grüßt herzlichst,
Klaus Roeder
carpe diem yacht design
http://www.yacht-design.de/ http://www.yacht-design.de
Karwendelstrasse 5b
86926 Greifenberg
Von der IHK München öffentlich bestellter und vereidigter Sachverständiger
Sachgebiet Sportboote
Tel : +49(0) 8192 9987549
Fax : +49(0) 8192 9987554
Mobil: +49(0) 172 82508 67
skype: yacht-design
Konstruktion von Segel- & Motoryachten
Beratung in maritimen Fragen
Bauaufsicht & Vermittlung
Projektmanagement
Sachverständigengutachten
Steuernummer : 161/263/40765 beim Finanzamt Starnberg
Der Inhalt dieser E-Mail ist vertraulich. Seine Verwendung unterliegt urheberrechtlichen Beschränkungen und kann auch gegen weitergehende Schutzrechte verstoßen. Sollten Sie diese Nachricht versehentlich erhalten haben, bitten wir Sie, den Absender zu unterrichten und die Mail anschließend zu löschen. Jede Form der Vervielfältigung oder Weiterleitung an Dritte ist unzulässig.
This message is confidential. It may also be privileged or otherwise protected by work product immunity or other legal rules. If you have received it by mistake please let us know by reply and then delete it from your system; you should not copy the message or disclose its contents to anyone.
Von: pascal [mailto:steve@mcneel.com]
Gesendet: Mittwoch, 22. Juli 2015 17:56
An: info@yacht-design.de
Betreff: [McNeel Forum] [Rhino for Windows] Filleting of polysurfaces with multiple edges
http://discourse.mcneel.com/users/pascal pascal McNeel
July 22
http://discourse.mcneel.com/uploads/default/original/3X/a/6/a6da16630f2cb02f1cefc6db9312fdf09777784d.3dm tacktickinstrument_pg.3dm (360.6 KB)
Hi Klaus - here is a blow by blow-
tacktickinstrument (steps).3dm (1.0 MB)
The hardest part is seeing which surfaces need to be filleted to which, in Step 4…
