Hi All - Having issues incorporating this10mm fillet into this part any assistance is greatly appreciated.
Arm Rest Fillet Issue.3dm (896.7 KB)
Quite a number of edges have edge tolerances that are very large compared to the document tolerance. A step to start fixing them is, _Explode to get individual trimmed surfaces, the _RebuildEdges. If you then _Join the parts to get a polysurface, you’ll see that exactly at the region where the fillet did not work, the edges are not joined.
I do not know how you got to this point, but if at any point you used _JoinEdge to make edges meet, that is most likely the source of this.
My advice is to start over and trim with the document tolernace 0.001 and join without ever using _JoinEdge until you have a closed polysurface. Then attempt the fillets again.
what is the data for ?
if its a professional / commercial context rebuild it from scratch !
_explode
_untrimall
will show additional issues like unnecessary trims, nearly coplanar faces - and also you should do a nicer surfaces for this chamfer like stripe (yellow, selected)
turn on the control points and you will see the surfaces is overly complex.
if you work with _blendCrv always check the _curvatureGraph and make sure not to have inflections / change of curvature-side (convex-concave) in the “smooth-arc-like” transitions. (S-shaped curvature-Graph)
post an updated file (including curves, untrimmed surfaces, …) if you still have problems.
happy modelling - kind regards - tom
Thanks Tom!
Thanks Menno!
