I fear that if I think I am done on the shapes then fillet to get the radiused edges, then better info comes my way so I have to revise sizes and shapes, now that they are filleted, doing so will be denied me.
If I need to shorten an object using scale1D for example, will the fillet remain at 2.5mm rad ?
If I need to alter its diameter will the fillet remain at 5mm rad for example.
Will a fillet still be from surface to surface if I alter the size of one object and the intersecting one stays same size ?
At thr moment I create a copy of the file for filleting, knowing I can go back prior if need be.
or create copies of all the layers and dupe them with content, name them pre fillet.
