FilletEdge
Hey
How to fix filletedge: http://prntscr.com/togxnc
Cheers!
Category Moved. And you can post images directly here.
Cheers,
BVR
If you want any useful advice on your filleting problem, it is better to post a 3dm file. You can use the “Upload” button when you write a reply (arrow-up).
Isnt it a common problem?
Untitled.3dm (260.1 KB)
the problem is the sphere seam, if you move it like this. it works fine
why is it like that?
Filleting is a difficult operation, and the sphere seam can make it more problematic because the fillet has to “reach over” the surface boundary (the seam is a topological boundary between the east and west of a square surface where north and south boundaries are shrunk to a point).
However, this is quite a simple case - the intersection between a sphere and a cube - and it may be a good test case to improve the filleting algorithm.
Well I didnt understand any of that. Hope it wont disrupt my work in the future.
Hello - please see the chapter on Nurbs surface topology in the level 2 training material -
https://www.rhino3d.com/download/rhino/6/training-level-2/
