After revolving the shape, I applied FilletEdge with a radius of 0.05 to a 0.5-thick object. The shape itself doesn’t look rough in the front view, but when I zoom in, I see a rough mesh on the filleted edges, as shown in the right view. Should I reduce the radius further, or could there be another mistake I’ve made?
Hi Jiin -
To be able to show NURBS geometry in a shaded display mode, a “display mesh” needs to be created based on the actual geometry. It is this display mesh that you are seeing as a rough mesh; not the object itself. You can change the settings for the display mesh either on the object itself, or for all objects in the document. Making a finer mesh leads to slower redraws of the scene but whether that is noticeable depends on the settings and the objects in the scene.
For more information about the render (display) mesh settings: Rhino Mesh Settings [McNeel Wiki]
To change the render (display) mesh:
