HELLO! Tell me, please, how can I select rounded curves using this filet?
Give thanks! It’s just that this filet has a slightly different operation algorithm, which is more relevant, but in this case it works the same way, thanks anyway!
If you want only the fillet curves, you can do this; note that the Disc ‘L’ input is set to C2 (Curvature).
Fillet_2019Sep28b.gh (11.6 KB)
I messed around for awhile with the Fillet you used but never managed to get both fillets on one curve; got two complete curves instead with one fillet in each; just as you had already done. But I can’t see the difference?
P.S. Fillet surfaces (below): Fillet_2019Sep28c.gh (14.1 KB)
This is a very useful solution. Thank you!
