FILLET Option not showing up
How come I cant fillet the bottom of this object
Hi Delayna -
As requested in your previous threads, please post the 3dm file. It’s very hard to troubleshoot an issue from an image.
Exercise57.3dm (269.8 KB)
Hi Delayna - if your question is about FilletEdge, that command only works on joined edges - your object is made up of separate surfaces - Join all the bits on each side of the parting line to get two objects, then fillet each.
When I try to fillet the top surface it goes like this
Hi Delayna - in the file you posted previously, there are multiple extra surfaces in the top bit - Explode that and click on each face - you can see where the doubles are where the red color is deeper.
Then join it up again - any better?
yes that worked thanks!
