Fillet Odd Edge
I am trying to fillet the edge in this shape to 0.05" to mate to the attached above.
The fillet radius can go to zero after that.
No matter what I try I get
“Failure in building corners.”
Problem72.3dm (538.7 KB)
What sequence might I use to get a 0.05" radius at the top?
if equal radii collide they have to generated simultaneously
Problem72 mod.3dm (575.6 KB)
I should have included a pictures. I was trying to fillet the edges that form a triangle. Even if I set the end radius to zero it does not work.
