I have a problem with fillet edges again.
I have just started learning rhino and designing jewellery in here.
The model at the attachment was modelled with 90 deg. curves. I used Loft to model the top surface and sweep2 for the side surfaces.
After making all surfaces, unioned them and then I wanted to fillet the edges. But it doesn’t work. I started the file by setting the tolerance which is 0.001.
Also, I tried to make the same model with filleted curves for the edge looks like a cog wheel. But this time. The sweep2 didn’t create the side faces.
I need a bit filleted edges all over the object. What is the best to do it?
What do you suggest to model this type of object?
Turkan
