Fillet edges of a shape
I am trying to fillet the upper and bottom edges so they will have a more rounded edges in direction down and up. How can I do it?
temp.3dm (256.3 KB)
Thanks
Did you try the command FilletEdge ?
Yes, but I do not know which parameters to change in order to achieve it
Just fyi,
You also can set different values for different edges,
important:
you have to fillet the red edges to get a fast and geometrical valid result.
as a workaround you can set the Radius of the red edges close to 0 which is 10x document tolerance
in my example:
Radius = 0.01 for the red eges (document tolerance 0.001 * 10)
Radius = 0.3 for top / bottom
if this does not fit, please post a sketch what you expect the fillet should look like.
kind regards -tom
