Fillet Edge Tree Management
Hey fellow Grasshoppers,
I’m having trouble with a project close to the finish. I have lofted 100 voronoi cells as shown in the pictures. Fileting the interior edges proves to be difficult. I am quite sure its a data tree managment problem that I cannot identify. I wanted to shift the tree until interior edges match to what is coming from the loft, but the lofts seem suprisingly undercomplex. I hope its something easy I am missing here and would appreciate your help.
Thanks in Advance!
Good morning @Devin_Can
If I have it right, I think that the Edges variable is actually looking for an integer. (1,2,3,4,6) = edges (1,2,3,4,6) Let me double check that this is all correct.
Good eye considering no GH file was posted.
@Devin_Can please read this:
3. Attach minimal versions of all the relevant files
Hey Joseph!
Sure, here is my gh-file. I hoped it was a easy mistake the members of this forum would immediatley see. :slight_smile:
ghhelpforum.gh (77.0 KB)
@Ryan14
Only an integer? I thought the E input wants all the edges that need to be filleted. How would an integer express this?
A list of integers corresponding to the sequence of edges from Deconstruct Brep ‘E’ output. Had you posted your GH file originally, I might have done more but it’s too late for me now.
Understand! So Brep Edges was wrong. Ill try it with DeconstructBrep.
Thanks so far!
So after finding a suggested way on another forum, Ive tried several methods, none of which seems to work. I cant figure out, why the Loft gives me Data with 100 branches, but BrepDec gives me {0;0} (x,x,x) formated List. this way the count will always exceed is my assumption. It feels like I am wrong on a very basic level. Help is still much appreciated.
Thanks in advance.
ghhelpforum.gh (79.9 KB)
@Devin_Can
Here, this should work. Problem is… Your edges are not all filletable. Also, Deconstruct brep still gives you the edges, not the indices. The below should be close to what you are looking for.
I understand how it can be a little confusing. I made the mistake when first starting out also. It did seem a little counter intuitive that you could not plug Edges into Edges.
GhHelpForumFillet2024.gh (81.9 KB)
Thank you Ryan. My PC is loading right now, so I need a moment to evaluate what you took the time build for me. Thanks for that.
As for the “not filletable” part: Is it because they re to close to each other, or is it because I effed up somewhere along the line?
Ill need to think a bit more about the indices and edges issue you raised. Im not sure if I understand correctly.
Oh, closest point did the trick!
Thank you. I was wondering how I can crossreference the edges and the interiors I was able to find out. Funny enough “crossreference” didnt do the trick :smiley:
Hi @Devin_Can,
Here´s a simple example that might give you some insights on how it works. There´s other ways to find the edges and understand the concept but I think that it will do more harm than good at this point.
The goal in the attached example is to add fillets just to the 4 top holes edges.
fillet edge.gh (64.2 KB)
Thank you very much!
I will study it. I solved my problem by implementing a fillet to the curves which I lofted. That didnt work for some reason, when i tried it earlier, but now it works, so I wont think to much about it.
Finding edges will become an important skill anyways, so Ill look into it @kossatz !
It doesn’t (R7). Fillet Edge took 1.3 minutes!?
  1. Fillet edge operation failed.
I wasn’t going to solve all the other problems with this. I was just showing how to reference the edges correctly.
missing
You are using Brep Edges ‘Interior’ which, in this case, happens to be the same as DeBrep ‘E’, but that is not always the case.
Using your brep with the same goal to fillet only the edges of the holes on top, here is another way to find the edge indices automagically:
fillet edge_2024Jan2a.gh (36.4 KB)
Thank you @Joseph_Oster !
Yes, match text was also an option I tried. Not as sophisticated as your attempt, tho. Problem with this one was, that some of the lofts at the outer rounded corner of my project, had the wrong name for this to work 100 percent. This is so tricky, that I more than once thought about doing it manually. That I didnt pull through means, I most def need to learn the automagic :slight_smile:
