I’ve selected an edge on a solid object and have set the fillet to .06 – the edge shows a readout of what looks like a 0 3/4" – this doesn’t look right, although the fillet works.
jvm
jvm
Assuming your model units are set to feet, and your distance display is set to feet & inches, I would consider this expected, as it is displaying in feet and inches, although it is a bit odd that the command line and command feedback are different units. If you change your distance display to Decimal, filletEdge will report back in decimal feet.
Sam
Units or DocumentProperties > Units
What “Model units” are set? What are the “Distance display” settings?
Sounds like your model units are feet and your distance display setting is fraction and 1/4" increments.
Again assuming feet as your model units, 0.06 feet (x12) = 0.72 inches which would round off to 3/4 inch.
Thanks, adjusted display setting to decimal as suggested, now reads as I would expect it to.
jvm
