Do you know why it is showing me two dimensions? I want fillet edge with one dimension, but I don`t know how I can change it. I am attaching a picture.
Hi -
It shows you the maximum possible value for a fillet on that edge. If you pick a radius that is smaller than 0.4, that second value will disappear.
I added this description and the video clip to the edge and surface fillet/chamfer/blend command topics.
If a radius is set larger than the edge radius at the handle location, the handle changes to dark red and displays the edge radius. It is the maximum radius allowed at the handle location. In the case below, a radius larger than 3.102 units will fail.
Can someone please fix the spelling in the title?
Fixed.
