HELLO,SWEETIES,I tried the fillet edge command,but it seems makes the wrong answer,odd holes shows, it’s confuse me a lot,why this happen?
test.gh (24.2 KB)
test.gh (24.2 KB)
It looks like you’re trying to fillet more edges than needed. If the objective is to only fillet the edges that are slanted, use the cull index for all indices from [0..12] - that should leave edges [27..30].
But filleting the lower horizontal edges at the same time, like your preview suggests, leaves gaps. This also happens in the FilletEdge command in Rhino.
thanks for reply, i tried it in rhino,it’s get the same holes too , that’s wired ![]()
If you zoom in to the corners you can see that, due to the dimensions of the object, the horizontal fillets do not touch exactly at the bottom. This is the origin of the problem.
the Distance From Edge option prevents this, but still does not fill the holes. An option would be to make a surface from 3 edges, followed by MatchSrf on all three edges:
So hard to learn, it’s killed thousands of my brain cells so far,my hair drops endlessly ![]()
Maybe take a step back: what shape are you trying to get to? What should the corner look like?
I don’t know either
, someone asked me yesterday, and i didn’t solve it effectively, so i asked on this forum, thanks for your warm help
