Fillet Curves in Grasshopper
Hey folks, apologies v basic, am new to grasshopper.. Using the fillet function and the rad maxes out well before the length of the lines i’m filleting. e.g. lines are 40mm long and rad stops at 32 instead of e.g. 39.9mm.. (slider has excess range) any suggestions? Thanks!
You should include the .gh file.
? Because the slider sets the fillet radius to be 32 mm? Or are you saying past 32 mm on the slider, the fillet cannot be made? In that case the lines are not orthogonal and a fillet radius of greater than 32 mm cannot be fit into the corner.
By rights, it should not be because the polyline is made of line-like curves. If it is a bug in the Fillet component, I suppose you could construct it.
or just use the discontinuity component to get all the vertices without any unwanted control points, rebuild the polyline, and run fillet again.
Finding line like curves and segments that are barely visibly curved is something I have to do a lot to process fonts when automating my process to build giant letters.
Hi all, here’s the fillet element I’ve constructed, as you’ll see the ‘fillet rad’ slider does not produce a fillet of a radius any higher than half of ‘d2’ or ‘d5’ slider. Any thoughts?
Thanks!
fillet.gh (8.5 KB)
