Since there is no Serengeti - Grasshopper1 topic I’ll post it here:
Here’s a weird problem I’m getting in grasshopper for Rhino 5 as well as Rhino 6 beta.
When I try to fillet these curves with a radius of 3.00 mm it doesn’t work for a few curves and gives me the following error: 1. Solution exception:Object reference not set to an instance of an object.
After some more testing I think I found out what is causing this error. You see that some shapes in the corner already have a radius before I do the fillet. That radius is the same as the radius I’m trying to use for filleting all shapes. So changing that first radius seemed to have solved it. But apparently that error also makes sure the fillet doesn’t work on some shapes that had no fillet before.
Is it possible to have the component check for existing radius and have the component throw an error saying that the radius cannot be present in the shape yet?
